electrical power measurement with compactrio
It's me again. I'm trying to set up a very simple 1-phase electrical power measurement system. I have found this link: http://sine.ni.com/nips/cds/view/p/lang/en/nid/208111. Here it's done with a DAQ system. I would like to use the same code, but with the CompactRIO. The question is how to connect the channelinput of the voltage and that of the current, to finally get the power reading. And how can I get a sine figure on the chart?
See attachment.
Soedarman
(2,601 Views)
Hello Mr. Soedarman,
To do these Power Measurements it's better to better use the following software:
http://zone.ni.com/devzone/cda/tut/p/id/11336
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,575 Views)
Hello Thierry,
I took my time to study the example and finally it works. Now I'm using the code with Labview 2011 and cRIO-9022 with the cRIO-9114 chassis. Thanks for the help and motivation.
With regards,
Soedarman
(2,560 Views)
