elapsed timer behaviour
Hello community,
Please have a look at the simple code attached.
After Starting the timer for a consequtive time, the elapsed time indicator does not start at 0, the timer has started timing again priorly although the express vi has not been called yet.
I can not explain this behaviour.
Thanks in Advance
(2,811 Views)
Your Express VI is set to automatically reset once the time has elapsed.
Instead of using the express vi, right click on it and pick Open Front panel.  Study how it works.  Then figure out how to do it in your own code so that it will work exactly the way you want.
You can also use the Reset input so that you can reset it the first time it is called again.
(2,791 Views)
