ejecutable para msdos
Hola, quería saber si es posible crear un ejecutable de un VI para que se ejecute en MS-DOS. Si es así, ¿qué versiones de LabVIEW lo soportan?, ¿Sobre que versiones de MS-DOS podría ejecutarse?
Gracias,
(3,617 Views)
Hi, I wanted to know if you can create an executable of a VI to run in MS-DOS. If so, what versions of LabVIEW support it?, On what versions could run MS-DOS?
Spanish board
(3,608 Views)
YOu mean you want to open the exe from dos. You can use commandline to do so.
(3,607 Views)
I think that you must specify the version of operating system that will run when creating the executable from LabVIEW, isn't it?
(3,589 Views)
Hi djimenezamo,
    According to Zvezdana'S comment , LabVIEW is a graphical language that will only work in a graphical environment, such as Windows or MAC OS. Therefore, I don't think an executable made in LabWIEW will work on MSDOS.
David Oña
(3,570 Views)
