edit /control graph names in program
Hi
I am able to generate xy-graph from acquired data from instrument. But unable to change graph name by programmatically,  i need this thing very much as i have to generate graphs of 500 in number, plot/graph name also i want to link it with file name, so that by seeing the graph we are able to get the some parameter values in plot/ graph name.
I want to edit / link one text box with graph, so that it should be stored/saved with graph, when i save plot programmatically.
By seeing the graph , i should be able to differentiate betweeen plots by seeing the graph name.
please help
(2,660 Views)
Hi there
You cant change the graph name but you can change the caption. Right click on the XY plot and show the caption, then you can use the property nodes. Take a look at the attached program.
Hope this helps.
Ian
(2,654 Views)
