easy question array
Hello experts,
i have an easy question. I need to store data in a 1D array so that the first data is written in the place of index 1 the second in index 2 aso.  I've tried it but somehow either i only had the last data in all indexes or only the last data in the last index. I am posting you a vi. I know where i should change it but i need a small idea oder change in the vi.
Thank u for your help.
T
(3,808 Views)
Hi T,
Please see attache png and tell me if this is what you where takling about.
Christian
(3,803 Views)
Please save your VI in ver 8.2 and then paste it on the forum so that i may help in making it into what you want. Without seeing the VI i am guessing that you have elements or 1-D arrays that you want to append into a single array.
Its simple whether its the elements that you want to build into 1-d array or arrays that you want to make into a single array. Just use the build array function. Connect the input wires to the element and you'll have your 1-D array, provided you havent unchecked Concatenate Inputs in which case you will have a higher order array instead.
Anyways kindly paste it in changed format so that i may help.
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
(3,801 Views)
Is this what you are looking for?
Tim
GHSP
(3,757 Views)
If not try this one.
Tim
GHSP
(3,753 Views)
