dynmic calling function node configuration
Can We call a function dynamically using a call function node.
requirements - Function need to be selected dynamically, hope that Dumpbin will list the exported function in a dll to /out file
this needs to configure the Call function node dynamically .... is it possible?
help please .... suggest me if it possible with any other language too...
(3,017 Views)
No, the configuration of the call library function node cannot be changed in runtime.
You can make a node for every function call and use a case structure to call the respective function then.
(3,006 Views)
