dynamically getting the Instrument Class reference
Hi all,
I need to get the class ref of particular Instrument Class. For e.g, Agilent_E3631A.lvclass is one of the Isntrument Class present in the Power Supply Instrument. Then i have to get the reference of this Agilent class dynamically. If i have several other Instrument Class along with Agilent Class. Then by specifying the Name of the Instrument Class, i should get the Reference of that class.
Is there any way to get the Class Ref Dynamically. Kindly reply me if there is any possiblity...
Alagar
(3,067 Views)
I believe you are trying to use just about any instrument connected to the computer. I am not sure if it is possible through references but you should try IVI drivers for inter operability with different instruments.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,033 Views)
hi bot,
Actually i need to get the LVClass Reference...
I tried with the "Get LV Class Default value.vi" present inside the Programming\cluster functions in LabView.
But when i use this vi, while i am closing the vi. the labview got crashed and close by itself.
Is there any other option available to get the LVClass ref dynamically.
Alagar
(3,026 Views)
