dynamically calling packed libraries
Hello LiaLiu,
Did you actually try to run my code?
Your suggestion does not work on my machine.
Roger
Message 11 of 13
(1,961 Views)
Change the path to
ESM-DMM-156343-AG34401A.lvlibp\Source Code\Main.vi
You can use the "Get Exported File List" node (in the pallete under File IO\Adv File Funcs\Packed Library ) to get a list of the vi's (and suitable paths) exported by the lvlibp.
Message 12 of 13
(1,954 Views)
Hi Matt,
That Works!
Ya'know, when I played with the "Get Exported File VI, I only looked at the "Qualified Names" output, not the Paths array.  That was my mistake.
I don't understand why the top level VI needs the "\Source Files\" segment in it, but it works, and I'll take it!
Thanks a bunch!
Roger
Message 13 of 13
(1,948 Views)
