dynamic dispatch and call by reference node
Does dynamic dispatch not work with call by reference nodes? I get this message:
"You have connected a refnum of one type to a refnum of another type and both types are members of some class hierarchy, but there is neither a simple up cast nor type cast between the two classes."
In the reference node, the dynamic terminals looks like ordinary terminals, and not like dynamic ones.
LV8.2
(3,044 Views)
It does work, but with a limitation (bug?) and i was not correct in the first post.
The terminals SHALL look normal beause the call by reference node does not call the dynamic VI directly.
The input dynamic terminal work. The correct inhereted VI is chosen.
The output termnal does not work correct, it is always the most general class that comes out, and i have to manually cast the wire to a more specific class. When the VI is called normally the correct wire is created automatically.
(3,039 Views)
