dynamic Zoom in Garph
Is it possible to zoom dynamically(ie. through LabVIEW code) in a graph?
Raja
(3,078 Views)
Hi Raja,
yes it´s possible. You can use property nodes of the graph to set the range of the scale. Select the active scale first and set the minimum and maximum value afterwards.
Mike
(3,076 Views)
Hi Mike,
Thank you for your reply.
Is it possible to customize Graph Palette to show only X-scale Zoom option alone and make all other tools invisible in Graph Palette ?
Raja
(3,065 Views)
Hi raja,
              U can right click and choose visible items and select what is required alone.For x-scaling range u can use a property node
(3,053 Views)
