dsc - slow property node
I'm using the DSC (LabVIEW 8.5.1) module for alarm handling in my application. One requirement is to adjust alarm-levels dynamically during run-time depending on other system variables values. I wanted to use the shared variable property nodes therefore.
The problem is that they work very slow and I have no clue why. The simple Test-VI shown bellow takes more than 20 sec (indicator shows milliseconds) to update hi an lo alarm-levels of 200 shared variables.
Does someone now how to speed this up?
Thanks in advance,
ThHagel
(2,994 Views)
The property node take time and there is no possibilities to speed up this property.
 You could try to undeploy the variables and re-write the lvlib (is a ASCII File) and then deploy the library again.
Regards
Ken
(2,953 Views)
