dsc help
hello i'm a new user to the dsc module.
i started by adapting one of the server examples that came with the dsc module, then i registered the server, tested the server with the interactive server tester and saw the values changing as i wanted.
then i went to the tag configuration editor and created tag to match the items.
launched the engine but the problem happens when i try to monitor the tags, i'm only able to see the first value of the tag, the tag does not refresh.
i don't know if this information is enough for somebody to help me, if not please tell me what i shoul tell.
thanks in advance for any reply.
amonteiro
(5,896 Views)
"i'm only able to see the first value of the tag, the tag does not refresh."
This may be your introduction to the "update deadband". There are several deadbands associated with DSC tags and there is a Knowledgebase article outlining them here.
The value in the DSC tag engine won't change/update until the actual value changes by more than the update deadband. For new tags, it defaults (at least in LVDSC v6.1) to 1 (1% of a 0-100 range).
Fading out. " ... J. Arthur Rank on gong."
(5,887 Views)
And just to clarify my previous post: it's what the KB article calls the "Tag Engine" deadband that I was referring to. The default value can be changed in the Tag Configuration Editor by going to Configure>Default Parameters.
(5,880 Views)
thank you donald, that was the problem.
i was going crazy with this.
(5,872 Views)
