dsc boolean Shared Variable.
Hi all
I have the problem with the log boolean Shared Variable.
I want to log the  boolean Shared Variable when the Shared Variable only is changed from 0 to 1 and 1 to 0.
I set in Shared Variable Properties/Logging:
 Enable Logging - set
 Log Alarms & Events - set
 Log data - not set
 But the boolean Shared Variable is stored every 10 sek although  boolean don't changed.
With respect
Iskander.
(2,642 Views)
Hello Iskander,
I'm not quite sure exactly what might be at play here, are you perhaps using a IO server that is periodic and hence logging data after a set interval of time? Additionally, could you have bound a variable to an IO server that is different than the one you are expecting to have the value change logging to be resulting from?
Best,
Blayne Kettlewell
(2,623 Views)
