dsc Acknowledge Alarms
Hi all.
I created Shared variable data tape double and boolean and  run Acknowledges alarms by Variable Name.
Where is Acknowledging user & comment saved in CITADEL database?
How can I see Acknowledging user & comment in the database ?
Respect
Iskander
(2,544 Views)
You can view alarms that have been logged from DSC in Measurement & Automation Explorer. You can view these alarms by following the following KB. To view alarms and events after you have created the alarms and events view, select the Display tab to open the alarms and events Display view and click the Refresh button. To reduce the amount of alarms that appear in the Display view, use the Filter view. You can also view the Ack User and Ack Comment in the Filter view.
How do I View Alarms and Events with Citadel 5?
http://digital.ni.com/public.nsf/websearch/40D4B55AE102D53E86256DD80073996D?OpenDocument
Jordan
(2,526 Views)
Hi Jordan
I inderstud.
All are working
Best regards
Iskander
(2,510 Views)
Cuando reconozco alarmas en codigo fuente (en labview) me sale con el usuario que me he logeado, pero cuando lo hago ejecutable el programa me sale en ack usr no body .
Que otra configuración debo realizar para que no me aparezca nobody???
(2,473 Views)
Hola di3go, Por favor, volver a publicar esto en el foro en español. El enlace de estos foros está por debajo.
Gracias!
(2,465 Views)
