dsc 8.2.1 cannot write to shared variables error 1950679035
I am getting error 1950679035 ni_tagger_write when I try to write to my shared variables.  I recently upgraded from labview 8.2 to 8.2.1.  I also upgraded to DSC 8.2.1.  During the install, I had to upgrade my computer to SP2 (windows xp), which installed mdac 2.8 sp1 for use with dsc 8.2.1.
I have the windows firewall turned off, I checked with our IT dept and no upgrades were completed overnight (as the program worked yesterday using 8.2).  I checked and MAX will get a connection with the fieldpoint unit.  Everything is deployed from my machine, currently running under the dev environment.
I have looked at this thread, but I was not able to get anywhere, http://digital.ni.com/public.nsf/websearch/0D7B86F4B4D19A5E86256F9A006EECB1?OpenDocument and here.
Even though I have windows firewall turned off, I added all of the execptions to the windows firewall list.
It appears that the shared variable library is deploying correctly, as the the windows says that it has (when you run a vi).  I am progmatically deploying the vi.
I looked at the variable manager and I attached a screenshot below.  I am not sure if that means that it did not deploy correctly or not.?? (I was only watching a couple of the variables, I have about 20 total)
thanks
Kenny
(4,308 Views)
It appears that my problem has been solved.  Apparently our network had an internal error for a quick second and my nic did not like it.  So after I restarted again (fourth of the morning) it started working now.
Kenny
(4,304 Views)
