ds1104Z
Hello.
Please help me. I want to process simultaneously more inputs and outputs , in LV2011, for Rigol DS 1104Z. Could someone send me the vi as an example? Thanks. My email: jrlsv2010@gmail.com.
(5,778 Views)
Accepted by topic author JAROR
Hi Jaror,
you know this is a support forum for LabVIEW questions.
This is NOT the place to ask for someone do your work for you! (You might post in the "Job Offer" thread…)
When you need help you need to supply all needed information needed to suggest solutions.
- What do you mean by "more inputs and outputs"?
- What do you mean by "processing"?
- How do you deal with your Rigol device?
- Which VI are you asking for, when you write "the vi"?
- Are you sure about posting your email address in a public forum?
- Are you having any specific problems using LabVIEW?
We are willing to help as soon as you show your current state and are able to specify problems!
(5,773 Views)
Are you using the 1102 driver - http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=88AF154718E95366E04400144FB7D2...
You should be able to modify it for the extra channels.
(5,759 Views)
Hello.
Yes, I know, that is support forum. I am thank to you for your help. I learn LV step by step. I have made SW for transient events in electrical circuits using PCI 6229. Now, I want to make to same SW using DS1104Z.
1) One analog input is connected to the signal of the transient phenomena of the electronic circuit.
Second analog input is connected to the electronic circuit of the thermocoulpe.
One analog output is connected to the reset circuit of the some capacitor in circuit. It is constant voltage, rectangular.
Second one is connected to the biasing voltage circuit. It is adjustable voltage of rectangular.
2) I mean the processing is acquisition and processing of the signal. I was not very exactly, may be. Sorry.
3) It mentioned above.
4) The some file *.vi comes from helper. But I do not need at this time. I will test your help.
5) I have two email addresses. Both are correct.
6) I have no problem, just that I do not speak at length LV and I learn them.
I know, it will takes some weeks to make my SW.
So much for the explanation. I'm going to try.
Thank you again.
Jaror.
(5,739 Views)
Hello.
I found the rigol_ds1000_series.zip. It helped me a lot while.
Thanks.
Jaror
(5,702 Views)
