drivers for lakeshore 91c and keithley 181 required
I would like to get the drivers for Lakeshore 91c temperature controller
and Keithley 181 nanovoltmeter which works in the LabVIEW 5.1 version I
If any one can help me in this regard , it will be greatly appreciated
regards,
Libu,
IIT Bombay.
(3,330 Views)
In the dirver library section, look up the Keithley 192 multimeter. The commands for the 2 devices are a bit different, but I used the basic structure of the driver advailible for 192 and got my 181 working fine.
(3,330 Views)
Hallo Mr. Libu,
did you get any answer to your question?
I have got a similar problem, I want to controll a Keithley Nanovoltmeter 2182 over the serial interface.
Could you help?
Best regards
Franjo
(3,330 Views)
HOLA NECESITO LOS CONTROLADORES DE EL LAKESHORE 91C. ME LOS PUEDES FACILITAR?
HELLO I NEED THE DRIVERS OF THE LAKESHORE 91C. CAN YOU PROVIDE ME?
Julian Andres Angel Jimenez
Fìsico
Aficionado al LabView Colombia
(1,748 Views)
That's an obsolete instrument (1987), I doubt Lakeshore will write a LabVIEW driver for it.  But it uses simple commands you can send over serial or GPIB using VISA.
Manual - https://www.lakeshore.com/docs/default-source/product-downloads/drc_91c.zip?sfvrsn=9d1df5c3_1
Craig
(1,742 Views)
