driver problem
I get the following error when I tried to run my program on a computer with an installed LabView runtime engine: "tktds7kReset.viDriverStatus:(Hex 0xBFFF015)Timeout expired before operation completed". After I pressed the run button for a half a dozen times, the program would run for about 20 min to 3 hr and then stopped and give me these errors:"LabVIEW: An exception occurred within the external code called by a Call Library Node. This might have corrupted LabVIEW's memory. Save any work to a new location and restart LabVIEW" and "VI "Jitter Test with Temp.vi" was stopped at node 0x410 of subVI "tktds7k Set Measurement Source.vi"." I tried to fix the problem by installing the newest tktds7k driver, close all the reference that I can find, and a
lso use the �Auto-Close VISA� option under Tools >> Options >> Misc. >> Auto close VISA in LabVIEW. I can run a huge file for 5-6 hours in the development environment without any problem. Can you help? Thanks.
(4,263 Views)
Hello!
Take a look at the following document:
Receiving Exception Error in Call Library Node
This should fix the problem.
Sylvia Vences
(4,263 Views)
I replaced the visa32 dll, but the error is worse, the program doesn't run at all. When I clicked on it, it immediately said error and the only option was to close it.
(4,263 Views)
(4,263 Views)
(4,263 Views)
Hello!
What version of NI-VISA do you have installed in your computer?
If you do not have version 3.1, download it and see if that helps.
Sylvia Vences
(4,263 Views)
