‎10-05-2010 11:30 AM
Hi all,
I just got a driver from superlogics for modules 8000 who is suposed to work with LabVIEW 8.5.1 because the driver that you can get on their website is not working with LabVIEW 8.5.1.
The problem is I can't see the driver on the list "Instrument Drivers" in the block diagram.
Best regards
popo
‎10-06-2010 03:23 AM
Hi Popo,
Where did you install the files from your driver installer?
In order to get a palette in the Instrument drivers palette, you should copy the folder in C:\Program Files\National Instruments\LabVIEW 8.5\instr.lib
Olivier L. | Certified LabVIEW Developer
‎10-06-2010 04:19 AM
Hi Olivier,
Thanks, got it and it's working fine.
Best Regards
popo
