driver division using suruga controllers
I was recently assigned to add extra functionality to an existing labview VI project. part of the existing functionality is a labview stage controller for 3 stages using suruga controllers. Currently, I am only able to control the stages to a degree of precision of 1 micron. Although I can input lower numbers, the stages are fixed at 1 micron. I believe the problem has to do with suruga driver division where the minimum resolution can be decreased by dividing the driver step size by an integer. I found the suruga driver to do this, but I don't know how to implement it into my existing architecture. Also, how does the driver division relate to the pulse settings?
Thanks!
(2,495 Views)
It would be helpful to see your existing architecture that you are working with. Also, I would highly recommend posting this question in the Motion Control and Motor Drives forum, which can be found here:
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/bd-p/240
This will bring your question to other forum users who are more knowledgeable on this subject and it will foster a better discussion.
dK
(2,463 Views)
