dragging case structure to include objects
This might be a very noob question.
I have made a case structure with a lot of code inside it. And I also have a lot of objects/code outside it, so that the outputs from the code inside the case structure go to the ones outside it.
Now I want to include the objects that were outside, inside the case structure. There is a LOT of code outside too, it is a pain to increase the structure size, and then cut/paste the objects inside. Not to mention the multitude of rewiring.
Is there a way to include the objects outside when i extend the case structure over them? Right now it just pushes them and does not inlcude them inside it. I have tried all combinations: Ctrl drag, Ctrl+shift drag etc..
Thank You
(2,725 Views)
You can remove the actual case structure (right-click on it and select remove case structure) and "redraw"  it including the actually outside code (backup first).
Ben64
(2,713 Views)
The problem with that is that there are multiple cases.
If I remove the case structure, it will retain the case that is currently displayed but delete all the other cases behind it.
(2,711 Views)
