drag and drop "objects" in labview runtime
Sorry, I forgot to set it to LV2009. Now you have itSmiley Happy
Hossein
Message 21 of 25
(948 Views)
Can you convert them to LV 2009 again? I'm using an earlier LV version.
I don't really get how the moving is working in the dynamically register for events example, my labview knowledge isn't that good I guess, haha!
I understand the labview basics but things like the event structures aren't going very well. Also I still got still some difficulty's with arrays.
Tomorrow I will try to make some things myself and view some examples that are working with event structures.
 Edit: You were faster. 🙂 Thanks!
Message 22 of 25
(946 Views)
You uploaded the wrong zip file, it's still 2011!
Can you upload the right one, please?
Message 23 of 25
(942 Views)
sorry for that.
Message 24 of 25
(928 Views)
Hossein,
Your example is quite well done, and even if I guess that you did it quite quickly, I permit to suggest some improvements:
- Creating an FGV instead of 4 different subVIs would be better for efficiency, cleanliness, memory management and future evolutions.
- I'm not sure it's possible to insert it in a subVI as you did it, but why do you used Mouse VIs for movements instead of mouse move Events? (that's just a question, it would probably not change anything)
Whatever, it's a nice exemple probably easier to understand than dynamic events.
Olivier L. | Certified LabVIEW Developer
Message 25 of 25
(924 Views)
