drag & drop into LabVIEW
(Maybe, old version of both LV and Windows), I remembered some drag & drop operation into LabVIEW's path control for simplicity from like Windows-explorer.
In my current version (LV 2012 & Win 7), the operation could not be applied and I need to navigate all folders to locate the file.
Do you know how to release the blocking?
Labmaster.
(3,872 Views)
You can find helpful tips here by Saverio,
and I attached his example Vi
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(3,854 Views)
Are you talking about Dragging a file and Droping into the Path control to get the path of the file? If yes, it works for me with no issue. What is the issue you are facing?
(3,847 Views)
I have Windows 7 x64 with LabVIEW 2012 32 bit and I can drag and drop a file from explorer to a path control, or constant.
(3,783 Views)
