does anyone know if it possible read a g-code (CNC) with labview in order to control a 3-axis system?!I really appreciate any clues!
Seems that g-code(CNC) is a simple ascii text file with well defined (ISO standard) commands and parameters.
If you have a g-code file you can read you 'only' have to translate the commands to G (LabVIEW).
So yes, I would say it is possible.... The rest is in the fineprin (including tool geometry corrections etc. )  ... 😄
Greetings from Germany
Henrik
LV since v3.1
(2,890 Views)
Try contacting Khaled, he may be able to assist:
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/G-code-interpreter-using-LabVIEW-done/td-p/2...
-AK2DM
(2,884 Views)
