do we require labview software installation on TPC-2212
I am using TPC-2212 and want to deploy a VI on it. I am unable to do it.Do I require full lab-view software installation on Touch Panel Target TPC-2212??
(2,508 Views)
Hello Axher,
Does the application window pop up at all? It actually should. If not, what does the VI that you are trying to deploy to your TPC-2212 does? Does it need drivers like VISA or DAQmx Base?
You just need to install the Touch Panel module on your development computer, build the TPC application, and select to deploy it. Please try to follow this Getting Started guide for steps on how to deploy your application. If you have problems on any step, please let me know what it is so that I can assist you.
Also notice from the Best-Practices for Touch Panel Deployment that you would need to do a separate install support for Shared Variables.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(2,484 Views)
