07-02-2014 03:43 PM
Well I am trying to Generate and record signals in saline solution simultaneously for 4seconds. Im using 81 channels to record this so i wanted around 324000 samples total or 4000 samples per channel.
07-03-2014 10:39 AM
Are you still going to help me?
07-03-2014 11:18 AM - edited 07-03-2014 11:22 AM
Okay just try to recapture what you are saying:
You want to have 4000 samples pr. channel from a 4 sec. run.
That will give you a 1kHz sample rate, no matter how many channels you have.
Then you are reading from 81 channels? That is a lot of channels.
Do you only want to read your input signals for 4 sec?
Start by trying to read one channel at 1kHz sample rate for 4 sec.
Try to read 100 sample from the DAQ every loop iteration.
That means that your loop should run 40 times. ( 100samples@1kHz rate * 40 = 4000samples@1kHz rate = 4000ms = 4 sec)
Then adding 80 channel after that should be easy.
07-08-2014 12:52 PM
I want to generate and acquire signals for 4 seconds and ill try this. Another thing is that I am losing data from my tdms file to another labview vi why is this.
07-08-2014 01:24 PM
According to Excel I am getting 4000 samples per channel at a sample rate of 1000s/s using 81 channels over 4 seconds. But when I try to run the excel file in labview and see the size of it, it only reads around 2900s/s. Can anyone tell me why. I attach the file that I am using.
07-08-2014 02:22 PM
You are missing a couple of subVIs, so we can't really see what you are doing with the data. Zip up your project and post the zip file.
07-08-2014 02:28 PM
Sorry here you go.
07-09-2014 07:30 AM
Still missing the Read Data.vi.
07-09-2014 07:34 AM
07-10-2014 01:37 PM
Here is the read data file i just need help understanding how it runs.
