dll
Hi All,
i use LabVIEW 8,5 student edition to make a DLL Programm.That means ,i will create a DLL with a or some VIs.
I havn't found somewhere that i can do this. For example, in LV 6i there is a Build Application or Shared Library under the Tools menu. Is there also somewhere just like LV 6i? or Somewhere else i can go on with this?
best wishes, and thank you!
Chun
(3,250 Views)
Hi Chun,
you have to create a project. If you have the application builder you will see the point "build specifications" where you can choose "create dll".
Mike
(3,248 Views)
Chun,
the student edition of LabVIEW does not inlcude the application builder (refer to this KB).
I am sorry, you have to purchase the application builder as an additional tool.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,247 Views)
