dll for cRIO
I am trying to create a dll that runs on a cRIO.
I have a VI including a CallLibraryNode that runs on a PXI system without any problems.
But when using the same vi on a cRIO, I always get an error:
Failed to load shared library on RT target device.
I have already tried to simplify the code as much as possible.
At the moment, I only have the function but without any code in it.
The dll is compiled with Visual C++ 6.0.
Is there anything special about creating dll's for cRIO?
Or do I have to install special modules on the cRIO?
Thank you.
Christian
(4,070 Views)
Christian,
Sounds like you're running a VxWorks-based cRIO. As mentioned in the KB, VxWorks is a Unix-based OS capable of running shared libraries compiled as .out files. You can learn more about this in Developing Shared Libraries for the cRIO-901x and Other VxWorks Targets.
If you are not running a VxWorks-based cRIO, I'm curious if you're accessing some NI driver code (or something similar) that is installed on PXI targets and not cRIO targets (such as NI-DAQ).
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(4,056 Views)
Michael,
Thank you for your reply.
I am not sure if this is a VxWorks based cRIO. How can I check this?
In my latest tests, I was using a complete empty dll, only one function was defined but no code inside. Therefore I don't think that this could be a driver issue.
Thank you.
Christian
(4,052 Views)
@ChristianEC wrote:
Michael,
Christian
By checking the type number of your cRIO. If it is a 901x model then it is a VxWorks based model.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,029 Views)
Rolf is right.  The cRIO-901x models run VxWorks compared to the 900x models that run PharLap.  Most people don't know this because LabView real-time seems to handle all this for us behind the scenes.  I believe the 901x models are just the 9012 and 9014 currently.
"If you want to succeed... Architect" - The Specialist
(4,007 Views)
Thanks to all of you, this was the solution.  When compiling with the gnu compiler, I can load the *.out and run the VI.
(3,996 Views)
