dll files
i m giving a cluster and some unsigned long integers as input to a call libraray funtion node . the call library function performs the task of transmiting the messsage to a particular protocol ID .....but when i run this VI ..i am getting this error "The specified protocol type within the message structure is different from the protocol associated with the communications channel when it was opened"................
i am using labview 7.1
(2,631 Views)
I'm not sure how we can help here, as the DLL is telling you you're not passing the correct values. Without seeing the DLL, or how you have it coded, there's no way to help you other than to say to make sure you're passing the correct values in, or have the DLL somehow spit out what it thinks it received.
(2,614 Views)
