キャンセル
次の結果を表示
次の代わりに検索
もしかして:
dll build error in lv2014, not in lv2012
I try build 2013 labview.
it gave me below error.
Click the link below to visit the Application Builder support page. Use the following information as a reference:
Error -1 occurred at CDK_Utility_GenerateErrorCluster.vi -> IB_Source_Container.lvclass:Report_Preview_Error.vi
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (-1) or for its hexadecimal representation (0xFFFFFFFF).
Loading product deployment information
*** Error: An internal error occurred for which the cause is unknown. (Error code -41)
*** Error Details:
Error in MDF API function: _MDFCommon_GetNextLogMessage
Error in MDF::GetInstance - MDF static instance is not initialized!
*** End Error Report
*** Error Details:
*** Error Details:
*** Error Details:
0 件の賞賛
メッセージ1/2
2,550件の閲覧回数
Hi zy6,
I see that you've already posted this issue in another forum post.  It would be best if you continued to post updates to that original post instead of creating a new forum post when you've noticed a change.
Tyler O
Tyler O.
0 件の賞賛
メッセージ2/2
2,517件の閲覧回数
