dll Build error using HP 8563a driver
While trying to create a dll from multiples VI inside the HP8563a drivers i get this error message:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error -2147221480 occurred at Building DLL.
An error occurred compiling the DLL because a function or parameter name is illegal. Please verify that the function and/or parameter names are legal C identifiers and do not conflict with LabVIEW headers.
Additional Information: HP8563a_SpecA.c - 20 errors
 84, 42   syntax error; found '*' expecting ')'.
 86, 19   Extraneous formal parameter specification.
 87, 43   syntax error; found '*' expecting ')'.
 88, 56   syntax error; found '*' expecting ';'.
 88, 43   Declared parameter 'At0HzMs' is missing.
 88, 52   Declared parameter 'TD1' is missing.
 88, 56   Missing prototype. (Require function prototypes build option is enabled.)
 88, 56   syntax error; found '*' expecting '{'.
 88, 57   Undeclared identifier 'errorInNoError'.
 88, 71   Type error: pointer expected.
 89, 16   Undeclared identifier 'VISAResourceNameOut'.
 89, 37   Illegal use of type name 'TD1'.
 89, 42   Undeclared identifier 'errorOut'.
 89, 50   Operands of * have illegal types 'TD1' and 'int'.
 89, 50   syntax error; found ')' expecting ';'.
 89, 50   Illegal statement termination.
 90, 1   Unrecognized statement.
 90, 6   syntax error; found '__cdecl' expecting '}'.
 90, 41   syntax error; found '*' expecting ')'.
 92, 9   syntax error; found '*' expecting ';'.
ERROR_REPORTED_TO_USER
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
(3,705 Views)
Your previous posts indicated you were looking for the HP8563A drivers, but IDNET did not have them. Where did you get the drivers? Can you  provide a link?
(3,689 Views)
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=047150BB30A857EAE0440003BA7CCD... this is the link of the driver it's know also as the Agilent 856X series
(3,685 Views)
That driver doesn't have a HP8563a_SpecA VI in it.
(3,681 Views)
No but all the VI inside the driver package can control the HP 8563a spec A, i'm just wondering why when i build the dll from lets say the Configure Span....Query amplitude and etc... i get the error message stated above
(3,677 Views)
Because as the error description states, some of the control/indicator names are illegal and some of the data types (i.e VISA Resource) are not valid C data types. You can clean up the names and replace the VISA resource controls/indicators with strings.
(3,669 Views)
