dithering(reply)
now I have a good idea of dithering.. but How can I add the noise to my pci 6024e... what is the hardware necessary for do dithering?"
(2,820 Views)
You can use one of the NOISE generators in the Signal Processing tools, then direct it to one of the analog outputs of your DAQ card. You can then physically wire that output, through a high value of resistance, to your analog input. (This should be on the order of tens of megohms. You will have to experiment with the exact values:)
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,820 Views)
