display saved lvm file to graph with timestamp
I'm having headache displaying my data with proper time-stamping. There are so many methods to save data. here I've decided to save it as a text delimited file format as lvm. a segment of my vi screen shot is attached. I want to use this way instead of other methods is the flexibilty it offers. I will be able to add on more data to store as I develop the vi. (So I'm storing data from DAQ assistant and my calculated values.) I attached a the screenshot of the file I read too.
I would like to use another vi to open this file and plot it to a graph/chart to display as a trending of the data acquired. Can someone pls advise mi on what is a better way for mi to do it?
Thanks alot!
Poh
(4,281 Views)
Hi CP Poh,
Can you attach the *lvm file?
Sincerely,
Krisna Wisnu
Certified LabVIEW Developer (CLD)
Certified TestStand Developer (CTD)
Using LabVIEW 8.5.1 (2008) to LabVIEW 2024
(4,257 Views)
Hi Krisna Wisnu,
Here's the *lvm file. This file having the 1st element is the timestamp in seconds converted to DBL which I convert back to timestamp and fed into the "build waveform" t0, the individual channels as the Y and dt = 0.1. (Sorry I can't access the lab over the weekend, couldn't have the screen shot). The waveforms will be channeled to build array, and output to a chart. (where the chart length I defined to be very long (default 1024) Juz to ensure I can get more data displayed)
In this manner I can get the timestamped waveform for short duration. When I tried to load this attached *lvm file, the system hang. Error: Not enough memory to complete operation. This is just a 10min data! haiz... (But that attempt I made was to disply the 10 channels of data out of so many logged data.)
If there is better alternative, to writing it, pls let me know.
Thanks!
Poh
(4,244 Views)
Hi CP Poh,
I am sorry for the late reply as I have been pre occupied with other task.
May I know whether you have solved the problems that you were having or not?
If yes, kindly share with us. If not, I would like to ask few questions.
Eventhough it is only 10 minutes, if in 1 second you acquire 1000 samples, in 10 minutes you will have 600,000 data in 1 channels. Meanwhile you have 10 channels, which as expected, your PC will ran out of memory. Can you post the code to write and read? so that I can see which part is causing the problem?
Looking forward for your reply.
Sincerely,
Krisna Wisnu
(4,183 Views)
Accepted by topic author CP Poh
Hi Krisna,
Sorry for the late reply, I was rushing to complete my project, wasn't able to reply.
Yes, I managed to solve it. Anyway I used such high rate in the DAQ assistant is to allow continous mode acqusition & use a software filter instead of hardware filter. however writing to file in this way - writing string into .lvm, max is 10 samples/sec. unless I use tdm (I'll then log everything).
I wasn't able to display proper time-stamping was due to the fact that I didn't add in the start-time timestamp that's required in displaying of timestamp in waveform. I'll not be able to go down to my lab, & my machine do not have LabVIEW, so what I can do is to extract portions of my report to share.
For the portion that I used to display graph (can be seen from the attachment), I deleted the 1st column, which is the timestamp (for spreadsheet viewing), but extracted the 1st element - the converted to DBL timestamp when I start logging in the DAQ vi (written together with the header).
This extracted (could be seen as a bunch of numbers in the lvm file) and and converted back to timestamp type and wired to build waveform block, providing the start-time of the waveform.
Next, I replace the use of chart with graph, as graph is suitable for plotting data acquired, and chart is better for run-time display of data. now it seemed to work fine for me, except for loading time may take a while for larger files.
Thanks for your participation in this thread!
Cheers!
Poh
(4,114 Views)
