display message
dear sir,
          i have multiple string output and i have to display in single indicator as a message can any one explain how to do with some example.....
Message 1 of 11
(4,008 Views)
Do you mean Array of string ? If it is a array, use Index Array(it is under Programming>>Array) to get the single value...
Message 2 of 11
(4,005 Views)
thank you sir for your reply ...
i have different case structure each case structure has an output  and i have to display all the output in single display...
Message 3 of 11
(3,999 Views)
Use Concatenate Strings to display in a single string.
Message 4 of 11
(3,995 Views)
sir if i use string concatenation i am getting combined output but i have to get the output one by one....
Message 5 of 11
(3,991 Views)
I guess you want to make a string indicator, where you can add a messages with status etc. (if I get it correct). I have some old code, which can help you. You can make a subVI, where you use a reference to the string indicator and add the new info using the property nodes. Just look at the attached file. I hope it helps you...
Cheers
Angel
Message 6 of 11
(3,985 Views)
Steps,
Does it mean you want the message to be displayed one below the other or the message to be displayed one by one with some delay inbetween.
Message 7 of 11
(3,982 Views)
hi steps,
why not you share you VI for better understanding...? if it is not confidential 😞
G'Ramy
Message 8 of 11
(3,961 Views)
Then you place an indicator outside the case and send all cases to the connection.
(Awaiting Altenbachs links)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 11
(3,930 Views)
thank you sir i got the solution ..... by using local reference to the indicator...
Message 10 of 11
(3,927 Views)
