display front panel when called
Here is what I am trying to do.
I have created labview dll and I want to call from CVI and also I want to display labview front panel when called from CVI.
which settings do I have to do in apps builder to make this happen.
Under VI settings, how do I change Show Panel to Yes. I tried all options but none of them worked.
Thanks for your help in advance.
Sheetal
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(2,672 Views)
Go to VI Properties>Window Appearance and select Dialog. This will set Show Front Panel When Called and Close Afterwards if Originally Closed. The app builder will then include the front panel.
(2,661 Views)
