display boolean in
i'm trying to capture the boolean results at the RESULT.vi but i couldn't get a notion on how to do it.
Can anyone help me?
Thank you!
Message 1 of 8
(3,884 Views)
Hi microes,
you already connected the boolean with the connector pane, so you only needed an indicator in the main vi (Result.vi).
But:
- you also have to wire a result to the indicator in the subvi
- you better give names to controls/indicators to avoid property nodes without proper labels!
- do as much as possible outside of structures (loops, cases, sequences) to get cleaner block diagrams (see subvi, lower right of the block diagram)
- act according to style guide: left to right wiring, no hidden wires, straight wires (deactivate automatic wire routing, if this is ok for you!), use labels
- your "result" indicator in the subvi only holds the value of the last iteration - is this wanted behaviour?
- to AND with TRUE is like multiplying with 1 or adding zero Smiley Very Happy
keep in mind: using "default if unwired" in case structures easily results in unwanted behaviour
Message 2 of 8
(3,865 Views)
Hi there,
could you save the revised vi you done in labview version 8? I couldn't get it to open in version 8.2, thank you!
Message 3 of 8
(3,845 Views)
Hi microes,
sorry for delay. Here comes the LV8 version Smiley Happy
Message 4 of 8
(3,832 Views)
Hello there,
i tried and the indicator in the ex op SUBVI works but the indicator at RESULT.vi doesn't seem to reflect the current result of the boolean indicator. Did i do something wrong?
regards
Message 5 of 8
(3,798 Views)
Your results.vi in the new image looks quite different. Maybe you should attach it so we can see what's wrong. 😉
Message 6 of 8
(3,785 Views)
I managed to attach the main panel that calls Subvi. Using Anritsu MT8852A, labview 8.0, WinsXP.
Thank you
Message 7 of 8
(3,777 Views)
Alright, i managed to solve this by creating another case structure with the "false" and "true" outside the subvi. Now it works, thank you for everyone's help!
Message 8 of 8
(3,768 Views)
