display an image from ftp site without copying to local drive
I have a camera that hosts an FTP site with images (.bmp) stored on it. I would like to display a real time image from the camera. I currently continually copy the file to my local computer and then display it afterwards, but I am concerned that the continual write to my solid state drive will cause issues long term. Is there a way to "stream" the image file directly to Labview and convert to image data type without saving locally?
I was looking at a datasocket read but I couldn't get any data out of the file and I get Error 42 occurred at DataSocket Read. If I could get the "string" from the file I could convert it to an image using the guts of the bitmap file open vi.
Any suggestions
(3,968 Views)
Accepted by topic author tshurtz
I don't do much with FTP, but I'd try the function Data communication -> Protocols -> FTP -> FTP Get Buffer. It appears to grab a single file and put it in RAM.
You can also try the information in this document:
https://www.ni.com/docs/en-US/bundle/labview/page/sharing-live-data-programmatically.html
to use datasockets to access FTP files.
(3,946 Views)
Is the FTP site seriously the only way possible to get live data from the camera?  That's not usual for a camera.  Are you sure there isn't another method to get a live image?  Can you tell us what model camera it is?
(3,922 Views)
The FTP get buffer worked and was the answer to my original post so I will mark it as the answer for anyone who follows, but I may have asked the wrong question as Kyle pointed out. I will look into other options they may have. Thank you both.
(3,844 Views)
It may not be the best way, but I think most cameras support an image server for "live" broadcasting, so it might be the most "universal" way.  Also, it might be the most convenient way to share a feed over the internet.
Bill
CLD
(Mid-Level minion.)
(3,824 Views)
can you share your vi, please?
(1,041 Views)
Here you go. Sorry it took me a bit to hunt it down. The sub VIs are modified versions of the library items that operate on the data sting from the FTP instead of from opening a local file.
(1,012 Views)
