display a text file on clicking a button
hi all,
I nedd ur help. I want to display a text file on clicking a button. This file should not be modifiable and should not stop the execution of other vi's.
Which kind of operation(switch when press, switch when release etc.) I need for this button.
Thanks in advance
(2,648 Views)
Depends on whether you want this displayed on the front panel of the main VI or as a popup window. If having it displayed on the main window's front panel is adequate then all you need is a string indicator on the main panel. The mechanical action of the button should be "latch when released". As to how to wire up a button, that depends on the structure of your main VI. Do you have an event structure? If so, you just add an event case for a button and in the event's case handler just read the file using the standard file I/O functions and wire that VI's output to the string indicator. If you want a popup window then you'll need to use the VI Server to launch a subVI that's basically just a modeless dialog box. You may want to brush up on event handling in LabVIEW. Check out the user manual as well as check out the examples that ship with LabVIEW.
(2,642 Views)
