displacement from time domain signal from a text file
Hi everybody,
I wrote a code for calculating displacement from acceleration signals. I have USB DAQ which I used to measure two acceleration signals, I subtract the the two signals and use SVL_integration.vi for converting the acceleration signal to displacement. I tested the program with a known signal of 1 g sine wave and the displacement which I got was correct.
The problem I am having is that when I read a text file with two acceleration signals and then use the same program to do the displacement, it gives me a value which is less than a factor of 100. I am not able to figure out what is going on. I tried converting the time domain signal to a waveform and doing the calculation, but the result doesn't seem to be correct. Any insight on what is going wrong is really appreciated.
(2,530 Views)
Hello npai,
Thank you for providing a screenshot of your block diagram; it sounds like you are attempting to determine the displacement between two objects by finding their relative acceleration along a known axis and using this to determine total displacement over a given period of time.
I think there are a few things that could be going on here- if you're able to provide more information on the results you expect vs what you are currently seeing, a "bigger picture" description of what you are attempting to do, along with (if possible) a sample data set, and the VI(s) you are using, it would help narrow things down a lot and help someone comment on what you're seeing or how to get the results you're looking for.
Tom L.
(2,501 Views)
