discontinuity waveform
I use oscilloscope to detect sine waveform. But it seems during the measurement, some data gets lost. I can only get 9100 points instead of 10000 points. Is there any problem with my setup? Thanks!
(2,547 Views)
Hey,
It could be a problem with the instrument driver. I would try debugging the tktds3k Fetch Waveform.vi and maybe also the tktds3k Config Acquisition Record.vi, because for both you configure the number of readings. If you have gotten the driver from the instrument manufacturer I would also suggest to ask them if there maybe is a known problem at this.
BR, Chrisitan
(2,515 Views)
