disable automatically close references
Dear Frinds
I am working on a project which cotains a main VI and a sub VI that starts when I press a button "Input/Output Setting" botton on the FP.
When I run the code for the first time the main Vi Runs correctly but the sub VI does not run correctly and returns Error1556
When I run the code for the Seccond time the main Vi Runs correctly and the sub VI runs correctly this time.
Consider that in these executions I do not make any change in the code but only I "Abort Execution" and run it again.
Please see the attachment.
What is the reason of this Error and how can I solve it?
Thanks in advance
Sincerely
V.S.
Message 1 of 8
(4,102 Views)
I can't look at you code right now, but I would be looking in the subVI to see what reference it is that is invalid.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(4,069 Views)
Dear Mike
Why can not you see my code? is it a problem with the Labview version?
Regards
Message 3 of 8
(4,022 Views)
No I'm on my phone right now...
Mike...
LabVIEW Champion
Message 4 of 8
(4,006 Views)
It's hard to say why you are getting the error since you don't have your error clusters connected. At this point you can't be sure that you are getting a good modbus reference going into the loop. Also, you need to get rid of the sequence structures, use the error clusters to set the order of execution. You should also learn a bit about state machines, that will help to simplify your code.
Mike...
LabVIEW Champion
Message 5 of 8
(3,943 Views)
Dear Mikeporter Thanks for the reply. There was good points in it about my clumsy code. As you see in the attachment I changed the code: I got rid of the sequence structures and wired the Error Clusters to set the execution order but still the problem exist! what do you think I should do with the problem? Sincerely V.S.
Message 6 of 8
(3,927 Views)
First, there was no attachment... Second, if you run your code with execution highlighting turned on, where is the first place you see an error?
Mike...
LabVIEW Champion
Message 7 of 8
(3,905 Views)
Dear Mikeporter Thanks for help. I found the problem by checking the code step by step using highlight. the problem was in a shift register which I forgot to use in a For loop. Regards V.S.
Message 8 of 8
(3,875 Views)
