disable array indicator but enable scroll bar ?
Dear All,
is there a way to disable an array without disabling the ability to scroll down with the mouse (scroll bar is also disabled if you choose disable in properties). The array indicator is clickable althoug not writable but causes confusion for the user...as if you can write something.
thank you .
Message 1 of 9
(4,198 Views)
Disable just the array.element control and not the actual array.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 2 of 9
(4,188 Views)
how ?
Message 3 of 9
(4,182 Views)
Hi mbhatti2000,
- Could you put up a small example of what you mean?
If you just want to disable the array indicator and gray it out, then you can use the property shown below.
Peter D
Message 4 of 9
(4,179 Views)
See very crude example
Paul Falkenstein
Message 5 of 9
(4,177 Views)
sorry here is the attachment
Paul Falkenstein
Message 6 of 9
(4,176 Views)
In pete's example, rught clich on property node and select link to, then navigate to pane->array->numeric.  This is now a property of the lement contained in the array.
Paul Falkenstein
Message 7 of 9
(4,170 Views)
You can also simply right-click on the array element, choose Properties then select Disabled from the Enable State menu.
Message 8 of 9
(4,163 Views)
Good point, Darin - I was stuck in 'programmatically mode' Smiley Very Happy
Peter D
Message 9 of 9
(4,152 Views)
