dijkstra's algorithm
Hey folks,
I am working on a dijkstra's algorithm program.  So far my program follows the shortest route and tells me the distance.  However,  I am not sure how I would go about finding the path that it took with the way I have the program set up.   I am fairly certain my program finds the shortest route,  have ran it numerous times and have been able to verify.  If anyone could help it would be much appreciated.
(2,850 Views)
I realized one of my errors in the system.  It could visit the same node more than once.  I believe I have fixed that.
(2,841 Views)
Can you post 2010 version ? I can try Smiley Tongue
Thanks & Regards,
Kunal Raithatha.
CTD - CLAD (I wish I can take off that A, and maybe use it later to replace D 🙂
Easy Tip :- "To copy an image to a VI icon, drag the image file and place it on the icon
located in the upper right corner of the front panel or block diagram" ...If you know any
more reply back.
(2,835 Views)
