digital waveform graph signal labeling
hello, i have a digital waveform graph displaying digital data.  i am trying to label the signals on the graph by using property nodes with an input array of signal names from 0 - 7.  Basically I have 8 plots labeled 0 -7.  my problem is when i plot the signals it begins by plotting plot 1 but it is labeled with the value 1 instead of 0.
for example:
this is what i want:
plot number        label
1                           0
2                           1
3                           2
4                           3
5                           4
6                           5
7                           6
8                           7
but this is what i get:
plot number        label
1                           1
2                           2
3                           3
4                           4
5                           5
6                           6
7                           7
8                           0
attached is the vi
(3,188 Views)
When you make the plot legend larger, drag it in the other direction.
(3,169 Views)
Just reverse the order of the property node, first ActPlot and then Plot.Name
Message Edited by Ruben_Oregon on 06-11-2008 02:05 PM
(2,906 Views)
