digital pattern generation using USB-6251
I need to generate two simple signals by using Labview with hardware of USB-6251 Mass Term. I thought it should be really simple, however, I've struggled for two days and found not easy at all (I'm totally new to Labview).
The two simple signals are attached in this post: one is the clock signal, but with limited cycles (NOT continuous), and one is the data signal which is supposed to be manually edited, also with limited bits.
I appreciate if anyone could give me any clue on how to do this.
Thank you very much,
Ruri
(2,609 Views)
You didn't say whether you wanted to use the digital output or analog output, both will work. But to use the analog output see attached. It may not be the most efficient way do it but it should work. You also didn't say how you wanted to input the signal, so I just chose an array of Booleans. Each element is a bit.
(2,590 Views)
