different x-scales
I use one waveform chart. Can somebody tell me if it is possible to change the x-scale from the graph (Controls;Graph;Waveform Chart), so that you can switch between different time scales in this one Waveform by clicking a botton(s)? (week, month, year)
Thank you
(2,639 Views)
What you can do is untick the autoscale from your X-scale and then dynamically adjust the range of the scale according to the button pressed.
See the VI attached as an example. Please do not take care of the presentation, I did it really quickly...
Hope this helps anyway !
Jumarion
(2,632 Views)
excellent work, thanks
(2,622 Views)
