different plots on same graph
In the attached VI, from the "Test List" I am able to plot the graphs depending on which "Test" that I select from the list (you can select more than 1 Test from the Test list and get the respective plots).  I would like to also have the added benefit of getting the different Temps also plotted.  So say for example, if I select Test "Power", I would like to also have a plot of Power over the different Temps of RM and +100 or -30.  Basicially I would like to get 3 sets of data (i.e. all the RM data, all the +100 data and all the -30 data) formatted in such a way that I can then select the Temp data the same way that I select the "Test" data
I am stuck as to how I should format the data to get a 3d array?? Will that help to get the desired result??
hiNi.
(3,278 Views)
Didn't you like the answers you got the first time you asked this?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,256 Views)
I want to add extra functionality to my code to make the program more versatile. I cannot get the previous solution to work correctly in this new strategy I am trying to implement.
Can you offer a method to get the functionality to make the code work by selecting one, two or three of the temp selection and then plot the respective graphs?
hiNi
(3,230 Views)
I have been trying to modify the code to get the Temp selection to work also, however, I have still been unsuccessful.  I seperated the Temp data and got a 3D array in the data_test2.vi.  However, now I lost some of the control that I had in the data_test1.vi.  In the data_test2.vi, I am having problems parsing the data correctly.  Can you offer some advice as to how to make a selection for the Temp also (added functionality from the data_test1.vi)?
hiNi.
(3,187 Views)
