different color of single plot on waveform chart
whether we can plot in waveform chart a single plot in different colors if yes then how.
Best Regards
Message 1 of 8
(4,929 Views)
you can have multiple plots in a waveform chart; to do this use a bundle cluster to the wavform chart.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 2 of 8
(4,928 Views)
thanx Harold Timmisfor your interest
my problem is that i have one plot and let suppose i have set thresh hold 2 when values goes above two the color of upper portion change to red and values less than two having green color please can you help in this sort
regards
Message 3 of 8
(4,925 Views)
use a property node it is called:
plot.color
to create a property node right click the waveform chart and go to create->property node->plot->color
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 4 of 8
(4,918 Views)
i have used the mentioned property but it change the whole color not the portioned color
Message 5 of 8
(4,914 Views)
so you only want a portion of your line to turn a color? because I do not know if that is possible
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 8
(4,910 Views)
thanx
Message 7 of 8
(4,906 Views)
maybe this post can help:
http://forums.ni.com/ni/board/message?board.id=170&message.id=149033&query.id=2658790#M149033
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 8
(4,904 Views)
