differences on the intensity graph
Hi all !
To do some measurements on a CCD-Camera-Image, I use the intensity
graph with an overlayed transparent picture.
The acquired image is converted to an array. The array sizes I use to
fix the Plot Area Size of the Intensity graph and for the Picture. My
problem is, that the autoscaled x- and y-axis show an other range
(275x260) as the real array size (255x255).
Whats wrong ?
(2,560 Views)
> Whats wrong ?
I think this is caused by the scale setting to use Loose Fit. Loose fit
rounds the outer markers farther out to be a multiple of the increment.
If you turn this off for the X and Y, the data values will be just
to the edge of the screen and labeled 0 to 255 or 256.
Greg McKaskle
(2,560 Views)
