difference in time to get time period
hello,
how can i use Get Time/Date to get the period between two time? For example, when i run the vi and press a button, the time is (4:05s). when i press the button again, the time is (4:48s). Then i should get the period (4:48-4:05 is 43 seconds). how do i do that? im using case strucutre, an i can only get the time when i press the button bot not the difference. any help or suggestions?
regards. aisyah
(2,634 Views)
Hi aisyah,
can you please show us your vi, or a picture of what you have till now? Thanks
Mike
Message Edited by MikeS81 on 01-20-2008 06:08 AM
(2,628 Views)
You get the time difference with a shift register and the subtract function. You wire the current time to the shift register on the right side of your while loop and to the subtract function and wire the left side of the shift register to the other input of the subtract function.
This is pretty basic LabVIEW programming. You should look at the on-line learning resources available at http://www.ni.com/academic/lv_training/how_learn_lv.htm
(2,621 Views)
